Rancho Deluxe
This was initially posted in a thread on troubleshooting wiring (Miss Elizabeth popping her fuse!),but now I think it needs its own thread. Lots of us may have this defective part installed and ready to fail. You can fix it, so read on.
Here’s my short circuit story. Just a few days ago my 1930 fordor stopped dead on the highway. It has 2K miles on a complete restoration and has been owned by me since 1956. Lots of trips with “adventures” but never before has this car left me totally disabled on the road. It happened after passing thru a brief but intense rain squall. After numerous roadside checks I could not find the short, so with darkness near, I used my auto club towing service for the first time ever. No fun, but the operator acted like he towed 80+ year old cars every day.
I needed two days to sleuth out the problem with a multi-meter, wiring diagrams, and expert interstate advice. Just about everything got checked. The flaw turned out to be in what you’d least expect – the one part intended to protect all the rest from short circuits. My fuse holder is a recent item from a parts house (can’t remember which one). It has a badly flawed design and differs from others I have seen. The car wiring end, not the battery connection end, has a bolt fastened thru the sheet metal bracket and the actual fuse holder. See the photo. Three small plastic washers insulate the bolt and first nut from the sheet metal. Less than 1/32 inch clearance is there between the bolt head and the nut sides and the bracket. Somehow moisture, a small amount of corrosion, dirty engine compartment dust or crud, or something shorted this fastener to the bracket and thus the car. When wiring was disassembled for checks the short was not observed. Upon reassembly the fuse would blow. This bolt and insulator design is just a temptation to Murphy’s law.
All of us using a fuse device should check for this flaw. It’s easy to fix. Just cut off part of the bracket with the bolt mounting hole and fasten the bolt and car wiring only to the actual fuse holder, itself. It would be helpful if someone with the older fuse holder without this basic design flaw would post a photo to remind everyone what they look like.
Good Luck, Rancho
Good Luck, Rancho
