Are you sure that's a Ford car shop manual?
The 279 and 317 are HD truck / Lincoln engines.
http://ford-y-block.com/Block%20identification.htm
Does it list the 239 or 256? Maybe it's an 'early' version of the manual???
1955 TRUCK had only the 239 and 256. The 272 was not introduced until the 1956 model run.
The '54 239's, big and little is just what I call them and that is nothing official. Just a way for me to identify the early and late castings made at the two different foundry's.
KULTULZ,
Is the '56 Mercury 256 a small cam or large cam bearing engine ?
From the above you posted, I'm not sure if you meant small or large cam bearings.
Thanks, Sal
Thank you KULTULZ,
Sal
