ford28roadster
my shocks on front leak but seem to work. will a kit with seals fix this leak and is this something i can do? thanks john also could i try stp in the shocks as its real thick maybe would not leak?
Call and ask John Holland. 330-483-3896.my shocks on front leak but seem to work. will a kit with seals fix this leak and is this something i can do? thanks john also could i try stp in the shocks as its real thick maybe would not leak?
I made a 4 piece set of shock tools, plus the angle iron mounting bracket, which are the most heavy duty tools I've seen. I made 3 sets. I sold one set on ebay for a very disappointing price. I sold another set to Jim in Wisconsin, and kept the third set for myself. The spanner wrench has a fixed pin to engage the hole in the lock ring, while the full circle lock ring tool has a movable pin to engage the hole.
Notice the large strap wrench used to unscrew the cover. I tapered the ends of the metal strap outward slightly so there is no chance of it leaving a mark in the cover. I don't have any dimensions or blueprints, but you can make your own tools by looking at the pictures.
The hex wrench has 6 tapered sides to match the taper of the hex in the shock. These tools took a lot of time to make, and I won't be making any more, but if you want a set get in contact with Jim Sinclair because he finished his shocks and has his set of tools for sale.
Tom,
Those are really nice tools!
Also you have a nice workbench too. Mine is all banged up!
I think my shocks are working but on a CCPU it is hard to tell! They are not leaking so I am going to leave them alone for now.
