eagle
Oh for crying out loud... have a little fun in life! Hook up the primary side of the coil to the battery + (Side of coil, top terminal) through a switch. Connect the bottom terminal (on bottom of coil box) to ground (body) Connect the secondary side spark terminal (lower side terminal) to any metal item that touches earth, such as a piece of chain, tin can, wire, etc laying on the ground. When someone touches the car, hit the switch. It'll light them up good but won't hurt them a bit. Of course it may also get their dander up enough so they may be wanting to throw a rock though your window or something! It will drain your battery if you leave it on. Some of you guys are so risk averse you wear suspenders and a belt at the same time, just in case!
