Yes, I have.
How do friction shocks compare to telescopic conversions?
In my view they don't. Most friction shocks you find today are made of thin gauge material and will not stand much tension adjustment.
While I am not here to debate those above who say their tube shocks ride just as good, I personally do not share their same view. When you think about it, someone is retro-fitting a shock absorber that was designed/calibrated for a different weight of vehicle often times with different type of suspension system.
The thing that I feel makes either a correctly restored original shock, -or a set of Stipe shocks much superior to these aftermarket tube shock conversions is there is a difference in the way they bias (60/40 action on the lever shocks) ...
AND the stock-type units are adjustable where you can fine-tune them to the road conditions you are traveling on. I know of no O.E. over-the-counter tube shock that has an external adjustment capability. Therefore if I have the capability to take a shock that was originally designed for a Model A Ford weight and suspension design, ...and then on that unit turn the adjuster to tune the exact ride quality I am seeking. From my personal experiences, that gives it an advantage. Maybe others don't see it that way, ...and that is OK too.
One question that I will ask. Have y'all seen these shock kits where a piece of flat bar is drilled and used to mount the shock? If some of us have said the tube shocks are stiffer, ...and we know from experience that a properly adjusted Model A shock has tension when the arm is depressed, what keeps that piece of flat bar from flexing before the tube shock starts to do its job? Thoughts??
