O old46ford Senior Member May 6, 2013 #1 How do the original shock absorbers work and do they go bad? What's inside them? Maintenance?
Vic Piano Well-known member May 6, 2013 #2 That's a question for Bill Wzorek (he is on the FordBarn), I'm sure he'll have a shocking answer for you.
R Rangerstan Junior Member Feb 2, 2025 #3 Disregard, just posting on an old post so I can get my newbie 9 posts so I can contact a member, never heard of probation for a forum
51woodie Well-known member Feb 2, 2025 #4 The attached will give the info you are asking about. Yes, they can "go bad". If they are not leaking at the pivot shaft seal, and there is good resistance in the arm movement with the shock link disconnected, that could be considered as "good". Attachments Houdaile Shock Absorbers .pdf Houdaile Shock Absorbers .pdf 1.3 MB · Views: 10 Flathead_Suspension_houdaille.jpg 47.3 KB · Views: 12 Houdaille Shock Drawing.jpg 73.8 KB · Views: 15
