john hamilton
Does anyone know of a SHINY black manifold paint? Most are flat black. Thanks.
I used a coating some years ago that came from Eastwood. Sandblast your manifolds, the paint them with the product. You must then heat them up slowly for a few cycles of heating and cooling, a little hotter each time, to cure the paint. If you just heat them right up to temp the paint will just burn off. This coating has a very glossy black finish.
Bob
Check out Caps Brite Hot Coatings in Fresno
www.capsbhc.com
Thanks for the comments. Nobody does porcelinizing any more - illegal? I used a Mac Auto grey paint for the V8-60 shown in my avatar. It sprayed on easily and had not discolored. It looks like fresh iron as you can see.
The shiny black is an attempt to replace the porcelin on a 1930 Packard.
