At pretty slow speeds (fortunately) the front-end starts a rhythmic oscillation where the front tires wobble back and forth. Probably called death wobble because it can be scary, especially if you experience it for the first time. Sometimes brought on by hitting an uneven section of road, a pot-hole, or maybe just because. It can usually be stopped by yanking the steering wheel to one side quickly, but sometimes not. The root cause is worn front-end parts. Like Tacoma Bob says, if you experience it, you will know for sure. Also, if you do experience it, you will be in great company.
