1955cj5
Does the small return spring that you removed look like this one?
https://www.brattons.com/throw-out-bearing-spring.html
I went back and glanced at your posts and I don't see where you ever measured your
free play. Pull the pedal all the way back till it hits the stop and them measure how much travel you have in the pedal till the throw out bearing just touches the clutch fingers.
Bob
Little update. Removed the spring, it is held on by the black wire seen in the video. The hub does not move forward/backward with the pedal at rest, if that makes sense. If I pull the pedal all the way back the hub moves freely. I don't think the spring is bad but I sure hope there's a fix for this without removing everything as I do not have the means to. Anyone else experience this? It's almost as if the hub is stuck when too far forward and need the pedal to pull it back. The car was sitting for a while, but I doubt rust could have formed in just a small section causing it to bind when forward. Two videos, essentially the same think just different angle.
Pulling the pedal back will not pull the hub back. With the spring disconnected the hub should not come back if you pull the pedal back.
Bob
30 Tudor, when I disconnect he pedal, the cross shaft if "free" but impossible for me to move in either direction by hand. Not even a little bit.
This needs to be free.
It needs to move easily by your little pinkie, with a vannila ice cream cone in the other hand. You forgot the ice cream!
You can hit the shaft through the inspection cover, you can see it on either side of the bearing running in the bottom of the bell housing running from side to side,, door to door.
Tap straight down on it,,,, on both sides of the bearing as far out as you can reach. You can also tap the shaft from side to side,,from the bottom,,,just be careful and do not flare the end of the shaft,,use a wooden dowel to hit the short end,(passengers side) then tap it back from the other side.(drivers side)
It shouldn't move very far, watch it and listen, you can tell by the sound when you have reached the end of any slack.
Have something to attach to the arm on the drivers side and move it back and forth, up and down,(short piece of pipe,, vise grips,ect.),spray with w-d,,,, tap,,,rotate,,,tap...spray rotate,,tap,,,rotate,,,spray,,don't give up.
Just be careful and don't beat things up and leave gashes and dents everywhere, it is not necessary to tear things up.
What you are trying to do is to gain some clearance in the bushings and wash them out, they will loosen up. Some times carb cleaner helps but it is nasty and will remove paint, and it's flammable if it's any good.
You could shoot a bit inside the housing at the shaft where it goes into the housing.
Plenty of clearance between the bearing and the forks when the pedal is depressed...hmm I don't know. Are the forks viewable through the inspection plate? I didn't see them but maybe I didn't look hard enough.
The ends of the forks or the fingers are on either side of the throw out bearing,,they push the bearing forward.
Is there clearance on both sides of the forks to the bearing.
And when you slide the bearing away from the forks do the mating surfaces look smooth,,
This is probably all ok as you said the main shaft was tight.
Don't just add more springs with out fixing it,(loosen it up) though that is ok,springs are good ,you need to get the shaft freed up or it will come back and haunt you later,, and you don't want to mess with this in the middle of a nice trip in all of your clean clothes,,do we?
What shaft, and does it matter where I tap on said shaft? What am I looking to accomplish...just to shake it loose? Or am I looking to remove bearings
from somewhere?
Just shake it loose baby shake it loose!
I agree with you, something is binding but I am not familiar enough with this and it is such a small area to work in making it even more difficult.
