stewgee
I like your idea as the spring is totally contained by the rod and washers, expanded on your idea I would use a washer just a little larger then the OD of the spring and cut three notches equal distance around each washer. This would allow you to not have to remove the washer to install the last two springs.
Sofield
Absolutely on notching the washers for the wire. Gonna file this one in the good idea bin. Thanks you guys. Learned a lot from this thread.
