You can buy what they call "E-Z" inserts.Not heli-coils. Its like a steel bushing threaded on outside for a bigger thread and a smaller inside thread. I use them some times on the hole up from the bottom on 94 carbs.Work great.They have diff. sizes. kenct.good idea B O B
tks
I get them at a local industrial parts place here in town. I'll get you the exact name of them later . I have the box from them in the shop.Maybe Mc Master would have them or a Graingers.ken ct. What sizes or size would you be looking for?? In and out sizes? I could send you 1 if needed. Cheaper than HC and you use a standard drill size for outside hole,depending what size the hole is.Hey Ken ct, where do you get those E-Z inserts? I too certainly have use for something like that.
Are they cheeeeper than heli-coils?
The holes in the knobs are bigger than the shift lever,SO how would that work???? ken ct.I took a bolt with right thread pitch and carefully drilled and tapped it to fit the shift lever.
