RJD,
It's especially important to check the clearance on the outside edge of the combustion chamber when you bore a lot. The cylinder can be bigger than than the chamber in the head. Check this with a big bore gasket. Also when you mill the head, the fly cut area over the piston will get smaller in dia., causing the same problem, good luck Chuck.
