Sharp dressed helmet ????
BUBBAS IGNITION
This made me you tube the tune " Sharp Dressed Man" bu ZZ top . This would be the ultimate sharp dressed helmet ... all the good stuff , 11A advance weights , small cam dual hd echlin points, new load tested condensor, gaskets and proper wire set .......polished case (Andy Tantes )
Ran on tester and adjusted then ran 5000 plus for a few minutes and rechecked ......
Cant for the life of me figure why you would ever run anything else ??? And this customer has the tubes as well ,
Gotta be the look with all the performance you ever need .....:eek:
And the brown plastic liesure suit ????
listen to the tunes :
https://www.youtube.com/watch?v=7wRHBLwpASw
430589
Nice Job Bubba, I like the diver there's a bit of the Botch in there because of Emel .I got a call out Frid night to fix one
Great looking distributor, that would look great on my 21 stud. Have to think about having the case polished.
Thought I would show some of Jim's outstanding workmanship. This V12 was converted to V8 . Coil was redone by Skip Haney. It will be used on a 1941 Mercury flathead. This is going in a pre war lakester. Should have fire going through it by the end of the year.
430783
430784
