1936coupe
suspension shackles sit at approx 40/45 degrees, what degree movement under normal driving would you expect from the shackles with rubber bushed shackle bolts? does the rubber bonding stop movement? the plastic sleeved shackles/bolts can move as much as is needed? just trying to understand the mechanics of it. thanks.
