Bruce Lancaster
The aligned gaps would have to provide enough flow to dump almost all the cylinder's energy, seems to me...no way.
I happened upon a manual for a 2000 Toyota V6 Camry this morning (had car for 15 years, have only glanced under hood for such things as refilling windshield washer. Can't tell you much of anything about the motor.)
Interestingly, there was a diagram of how to align rings at installation, AND all the gaps were to be in a 180 degree arc on one side of piston! So Toyota is still interested in these issues...
(looked at the Toyota ring placement charts again...the arc where all the gaps are to be put is the front of the cylinder in traditional terms, the end opposite transmission attachment... the engine is of course sideways to confuse me. That would mean it is spanning between the thrust and non-thrust sides, if that is a factor. Fortunately, I don't own enough metric sockets to tear in there and see where they are now!)
