bcatcmc
When I first starting to look at adjusting the lifters in the block ( assembly stage ) I thought there must be a better way. I could handle drilling the lifter bosses for the pin but with solid lifters I imagined a problem with the pin getting forced out with the shape of the lifter depression. Seems like I might need 3 hands here some where, bad enough with 2 hands in there, In the end I went with the following.
First step was to use an electric pencil to lable all valves and lifters ( Photo 1 )
I made up a spring loaded dial indicator jig ( Photos 2 and 3 ) with locating plate shown fitted. ( important )
With about 020” clearance valve to lifter I set dial indicator to zero.
I then used a nominal 035” feeler gage between valve and lifter . ( Photo 4. ). assuming intake being adjusted dial indicator should read ‘035” less ‘012” “ ( the lash required ). ‘023”
If the dial indicator reads above ‘023” ( example ‘028” means lifter to be adjusted in ‘005”)
If the dial indicator reads below ‘023” ( example ‘017” means lifter to be adjusted out ‘006” )
Photo 5 shows jig for adjusting lifter in or out.
Replacing lifter / valve back in the block with dial indicator back in place, with a ‘012 feeler gage should read 0 ( a double check of the set up replacing the ‘012’ with a ‘014” feeler should read ‘002” )
Photo 6 shows the adjust sequence used.
Initially a bit fiddly but after the first couple of times progress was good, consistently accurate, fairly civilised process and my knuckles still in good shape.
If anyone interested I can post up jig dimensions.
