Thank you much, Glenn. No excuses, but I've had 2 strokes= paralyzed left side,right and lower peripheral vision gone, and it is a chore just to get in the little 3W. Once behind the wheel, I'm comfy & not desirous of getting on the floor curled up, or flat back. Soooo, I just felt around behind the speedo, and missed the stem because the amp gauge wire is twirled around it.
So I did the task upon reading your generous answer.
My machined gauges panel has two little 'lights'; one upper right, one upper left. (no juice when battery cables are connected, although transport driver said that the car was driven on the transport. So Aug 27 I'm having two very knowledgeable fellows go through the car in their shop here.
All the best to you & all these good people on Ford Barn!
*** Those 2 little lights (half the size of a pencil erasure could have been directional indicators. I see evidence of a possible directional set-up on the steering column; also an under-each tail-light, a mounted red light. But why yank the directional set-up after the install. (no directional lights anywhere on the front.
'highbeams'
