All I can say is its a slippery slope...first its a plastic fan and serpentine belt,then you put on a B carb,then a high compression head,then a weber carb with an FSI,an aries muffler and mitchell OD..convert to 12v..then thats not enough so you pop for a B block with a Serr head,juice brakes and an f100 steering box..then one day,in a moment of sobriety you look at the car and wonder where the model a went..
I'm not sure of exactly what Snyder's sells with their serpentine belt, a system? At least part of the HP gain is from the extra flexibility of that belt, more flexible = easier to turn the gen & fan. I've been involved in dyno testing of performance A's, one time we took the belt completely off and I turned the water pump with a hand drill while a dyno run was made. From memory that was 3 HP. Don't recall if it had a serpentine or not?
Phil Irving https://en.wikipedia.org/wiki/Phil_Irving said that BHP stood for Brochure Horse Power.
