Bob NH
When I first bought this car it always showed 50 lb. oil pressure at startup and after warmup would come down to around 25-30 constant. I just noticed on a short drive the other AM pressure dropped to O and would only come back up a few lbs. and back down again. I do not dare to start it till I find out what happened. I checked today wondering if the sending unit had a loose wire and it was OK. Is there a way to test a pressure sending unit on the block ? A former owner spent "gazillions" of dollars on the rebuild including everything in the engine . I dread pulling the pan to see what has happened, I don't bend so good at my age anymore ! Ideas anyone where to start ?
