Nostalgic1930
Hey guys looking to get some insight on this situation.
i have a banger motor in my 1930 truck. and after running about an hour or so it pours out about a half a quart out of the cotter-pin hole. i took the pan off and took 2 shims out and still didn't do anything!
the cap had a hole drilled into it and the pipe looked to be cracked and welded back on, my question is what else could cause this oil to be coming out in such an abundance.
is it that the babbit is worn down so much ?
looking to pull the motor and get away with the least expensive fix for now, which would be the bearings re done and crank re ground? would a Brass seal help as well. much appreciated !
also was told if the cap was from another car it would never be right or aligned correctly because of the specific wear pattern to the engine, crank, and bearings
