A allford Member Sep 7, 2010 #1 Where can I locate serial number on 39 Merc. Engine? Will this number be the same as number on the frame? Thanks Alan
Karl Wolf Well-known member Sep 7, 2010 #2 There were no numbers on engines, my 39 has frame number and matching transmission number... Suspect many others started that way... Karl
Pothole Jim Member Sep 7, 2010 #3 If numbers are found they would be on the transmission bell, just above the inspection plate.
Fred A Well-known member Sep 7, 2010 #4 Does that mean that the numbers on my Long Beach made '47 coupe Were added to the engine when it was rebuilt? Shure do Look good.. Good luck: Fred A
