the human wrench
Can anyone tell me where the "secret" sequence number on the frame of a '56 Fairlane is? The door tag is missing and I suspect on another vehicle.
When did Ford start putting numbers on the frame? I was told they should be on the top of the right front frame rail of a '55 T-Bird when I went to title the car at MVD. But they couldn't find it on the frame (only on the vin plate on the firewall) and wouldn't give me a title.Sciala is correct and there is also one stamped in the rearmost crossmember,but it's stamped on top so the only way to see it is to remove the body from the frame.
I had the body off of my sons 56 Fairlane about 15 years ago and as i was prepping the frame for paint ,i found the cross member number. One on the top side right front frame rail and i believe i saw another one but don't remember where.
This is where it should be, behind the upper control arm but before the firewall. You may have to expose it with a wire brush to be able to see it.
Thanks. Does anyone make reproduction data plates for '56 Fords?
