Carb Guy
Hooked up all the wiring as per all the help Tom and several others gave me. Turned on the lights and the meter read charge so reversed the wires on the ammeter as per what all of you said to do, OK at that point. tried to start the engine but no luck at all. so went to Les Andrews book on trouble shooting the ignition. Got out the volt meter and started to go down the check list, 6 volts at the starter but as soon I checked past the fuse hook up on the starter the voltage dropped at all the further check points. So disconnected the fuse holder and hooked the yellow wire right to the starter switch, then I got 6 volts or a little more at the coil posts and both of the junction box posts Turned on the switch and put a piece of heavy paper between the points and no power there. I was having problems with my pop out it did not want to pop out unless I pulled on it then it would work. I had rebuilt a switch years ago so checked the continuity on it before installing it, checked OK .Checked it again and not working after installation. Pulled it out and hooked a trouble switch to the distributor. disconnected the red wire from the coil and hooked the wire from the distributor to the coil. Checked the points with the paper in between and now had 6 volts at the points. Tried starting again but no start. Checked the timing and reset it. Started it again and at least got a back fire. Checked the book again and said it could be a bad condenser so changed it , still no start. What do I do next this is just maddening?
