Hi
I have a 1952 ford f2 6cyl 226 it is wired 6 volt. I have all new wiring and gauges. I just installed a new temp sending unit and hooked everything up. I did not use teflon tape when I installed the sending unit, it should be getting a good ground. When I turned the ignition on the temp gauge remains pegged at hot and does not move to the cool side of the gauge. Am I missing anything? How do I tell if I have a bad gauge or sending unit? Thanks in advance for all of your help.
