1930artdeco
Hi All,
So I pulled the sending unit to verify that it works properly before I put fuel in the tank. I pulled it out and positioned the arm for "full" and it went right up to "F". I them put the arm in "empty" and it stayed at empty. Good so far. Then I moved the arm from empty towards full by about 1/4" and it shot to 'Full'. What should I look for on the inside before I open it up? Maybe I bumped something on the inside while cleaning it up, or I may not have gotten all of the shellack off the wires? Also, I am using a diode type voltage regulator on the instrument back for the gauges. Could the ohms be goofing the gauge up?
Thanks,
Mike
Thanks,
Mike
