andyleonard
After about an hour on the road yesterday, I let off the throttle in 2nd at about 15mph and the car lurched forward and locked up the rear wheels. Solid. Engine is fine, clutch is fine but either the trans or diff is locked solid. Trans lever won't come out of 2nd, rear wheels skidded off and on the flatbed, rev engine and let out the clutch and the engine stalls. I had a car once that broke a shifter fork and somehow got itself into 1st and reverse at the same time. This feels like that. If it were a rear wheel bearing, wouldn't the off-side rear wheel be fine? If it's the diff packed up, why is the gearbox stuck in 2nd? The car is in the drive and won't roll and I haven't had time to look at it yet. Where should I start? Can I get to the top of the gearbox from inside the car and unjam it if that's what it is? Can I release/remove the driveshaft? Thanks.
