Sedan Delivery help
meric42
I am looking for pictures of the head-liner retaining bows for the rear section of a '42 - '48 Sedan Delivery as mine does not have any bows from the just behind the seats back to the rear door.
I have several bows from a Fordor sedan but will need to re-work them as the roof shape is different to the Fordor in the rear of the SD.
I am also looking for the, 3 piece, radiator support bracketry that is riveted to the front of the chassis on '42 Fords. I need these from a V8 car as the 6 cyl. ones are different. Is anyone able to help with with leads as to where I might be able to source these parts?
Thanks in advance,
Meric42.
Are you sure that the headliner went all the way back? I know that on the Panel Trucks (different from Sedan Deliveries) the headliner was over the cab section only and did not go all the way back.
Thanks for your reply Vic, All the research that I have done confirms that the head-liner in these Sedan Delivery's did in fact start above the wind-shield and go right back to above the rear door. Cheers, Meric42.
btt I still need help to find radiator support parts.
What I need to find is the cross bar with the two plates that it is riveted to with one river at each end. Then, in turn, the whole assembly is riveted to the chassis rails (via 3 Rivets) at either outer edge.
