The issue I have is that the original head studs are not long enough, so I can't tighten them up to the shoulder. The original, short 59AB stud, 40-6065 is "2.340 OAL, it is not long enough for the combined height of the head at "1.250, the nut ".425, the washer ".080, the gasket ".060 for a total of "1.780. "2.340, less "1.780 leaves .560, or a little over 1/2" of the 7/16-14 USS threads to go into the block. The actual
7/16-14 USS threaded section of the stud that goes in the block is ".690, leaving ".130 of thread above the deck of the block. That is why I assumed I needed to not only seal the thread, but to secure it form moving.
