Brother A
I bit the bullet and pulled the steering box from my '31 Cabriolet to chase down the steering play. Everything looked pretty good except that there is a noticeable amount of play between the sector shaft and the sector housing. It looks like a new housing with needle bearings but it's not clear if the sector gear is new. Should that shaft be a precise fit or is some play acceptable?
Thanks
Steve
Thanks
Steve
