Second throwout bearing question
35 coupe
If there is an airgap, why do you hear a bad throwout bearing when you have no load on the clutch pedal. when you release the pedal and you here it grinding, it has to be in contact with the pressure plate fingers to spin. Thanks
There is a spring on the throwout bearing/bearing hub to retract it off of the pressure plate. The spring may be missing or damaged and allowing the bearing to ride against the pressure plate. Part #7562
Noticed in your other post that the vehicle is a 1950 F1 so I added the diagram for it, same part.
I had a bad throwout bearing and am replacing it now, new clutch, rebuilt pressure plate, and refaced flywheel. Just wondering why you hear a bad throwout bearing when it is not supposed to contact the pressure plate fingers until you push on the pedal.
Was the retract spring in good condition when you took it apart? If it was not retracting the bearing that would explain both the bad bearing and the noise.
Pretty sure when in neutral with the clutch engaged the engine is spinning the ****** shaft the pilot is riding on. If bad to the point of binding or partially binding on the needle bearings in the throw out bearing you'll hear it. The slip fit of the throw out to the ****** shaft will still let the throw out bearing spin. Pretty sure that's what you were hearing. Also maybe due to linkage wear / movement and not frequent enough adjustment may have been making light contact with the fingers.
In neutral with the clutch out (released), engine running, the trans input shaft is rotating the same speed as the clutch/flywheel/pilot bearing. So if you hear noise under those conditions, it's either the release bearing or the trans input shaft bearing. If the release bearing isn't touching the fingers, then it's the trans bearing.
