My wife was just uncomfortable enough without seat belts that I took the longest one out of the back of my van and connected each end of it with the biggest screw-on chain links to the biggest forged I-bolts I could get connected through the floor with huge fender washers and lock nuts underneath. I know - it's not going to keep my chest from being impaled on the steering column etc. etc. But it will keep us inside of the car if it rolls or the doors open and keep my wife from launching though the windshield. And, I can disconnect it for car shows. No one seems to see the eye bolt hidden behind the door post.
Old Henry,
I applaud you for driving your Ford as much as you do, and in all kinds of weather to boot! However, your seat belt installation is not good at all. What will happen, when and if they are ever needed, is a single occupant will be forced/moved to the center of the belt, and two passengers using the same belt will be slammed together. You really need to have a separate belt for each person so that it can be adjusted for minimum movement.
The belts should also be solidly bolted to the floor, not through any links.
Install the belts correctly, and they'll help prevent injury instead of causing it.![]()
My '36 roadster that I'm building with a Duval windshield and banjo wheel will have 3" racing type shoulder belts because of those stories. People may laugh when they see the mighty flathead in it and not think that those belts are warranted, but whose car is it?
My dad and i were going to do it, but law here in Minnesota states, that if you have "Collector Plates", you may have your car stock, without seat bests or airbags.
Old Henry,
. . . your seat belt installation is not good at all. What will happen, when and if they are ever needed, is a single occupant will be forced/moved to the center of the belt, . . .
Will be installing lap belts in the 27 T that I am currently building
That sounds good to me. I want to be anywhere in the front seat other than behind that steering wheel. That was the number one cause of death of drivers of these old cars - being impaled by the steering wheel and steering column that were being pushed toward the driver by a front end impact while the driver was slamming into it by the momentum of his body. That's why all modern cars have collapsible steering columns. I keep rehearsing in my mind my protocol for any front end collision if I have time - throw myself to the right of the steering wheel. My full width seat belt will accommodate that better than a single one that would prevent that. IMHO
