I have an original '36 Ford seat out of a 5W coupe and have discovered, recently, that the passenger side adjustment mechanism is NOT the same as the driver's side. Interface-wise, it matches the holes in the floorboard, it matches the holes in the seat pan, the general configuration and height are the same, but the adjustment provision itself is different (not from a '36) and I'm wondering what I have. Whereas the locking pawl on the driver's side is a stamped L shape piece of metal with a wire spring to hold it engaged, the passenger side has no provisions for the wire spring and the pawl (missing) appears to be a T shaped piece which perhaps employs a cylindrical spring on the outer side, held in place by a cotter key or some similar device to hold it engaged.
I figure the track must be from an earlier or later Ford, or perhaps a Lincoln. 3 pictures are attached, showing the place for the adjustment pawl, both sides, and an end view of the track. The end view is provided to show that the platform upon which the slider slides is actually a one piece T which is riveted to the base on both sides. The '36 platform is formed by bending the top of the base in one direction, then riveting an L shaped piece to it to form a similar T shape. If anyone has one of these and can provide a photo of the locking pawl, I'd certainly appreciate it......maybe I can make one.
Thanks
Thanks
