searching wide 5 wheels
JanP
Hi, does anyone know if there are any aftermarket wide 5? I'm searching for some im 16x6 or 16x7......
Someone an idea?
Regards Jan
Seems like maybe Speedway had some available for the roundy-round racer boys (and girls, too). DD
DDCOOPMAN Is correct on Speedway. However, most of the wheels they have already made up will probably be wider than you want, They also have wheel shells available that will allow you to make your own. If Speedway doesn't have them, lots of other places do. I made most of the wheels I use on my vintage modified. I mount them on the cars front spindle while that corner is on a jackstand. Spin them to make sure they run true and weld them up. I believe Speedway has wide five centers as well, but it's been a few years since I built any wheels. Speedway has a racing catalog that is separate from their street rod catalog. You should be able to find what you need on their website.
i had a pair of wide five wheels fabricated for the rear axle on my `37 1/2 ton, i think they are six inches wide. if your using the original shocks,you need to keep that i mind and don`t put all the offset to the inside. Marsh Racing Tire did the work, i HIGHLY recommend them. the completed wheels were within .015" T.I.R.
tom
Great help! Here in Germany it's really hard to get information. I will look up these opportunities.
