Ray Balukas
What are the thoughts on using seam sealer on the door skins? I realize this was not done in 37. The previous owner soldered the door skins. My panel is going to be a driver, but mostly original.
Seam sealer is OK but it can intrap more than it keeps out after it gets old and starts to crack.
So you are saying that you have actually seen Urethane seam sealer that has cracked or is it just speculation?I have never seen a sealer that doesn't crack over time and the elements. If you store the car in a temperature and humidity controlled environment, it will last much longer but it will still slowly deteriorate.
