seal
oldgas
Can anyone shed light on the manufactures name & part number for a rear pinion seal for my 1956 Ford Victoria my rear diff has 322 gear ratio if that means anything?
Thank you for your time.
Cheers Oldgas
... rear pinion seal for my 1956 Ford Victoria my rear diff has 322 gear ratio
SEDAN - 8A 4676 - 1 5-8"ID - 3" OD
The old seal will have an ID NO on it. Take it to a BRNG AND SEAL PARTS JOBBER and they should be able to fix you up.
Kultulz,
Are you referring to me as being a " so -called specialty vendor"?......,
We've been in business for 54 years......
:eek:​
LORD NO! ...
I was referring to buying from a trusted parts jobber (which is you) over these online off-shore parts sellers.
... I can get myself into more trouble ... :rolleyes:
