7_Zero
I had my frame media blasted and epoxy primed about a year ago and I am now ready to paint it. I am using 400 grit paper to scuff the surface, however there are pitted and uneven areas that I cannot get the paper down into. Will this cause bad adhesion problems or would the scuffed areas around it be sufficient to hold the paint?
I was reading about some red Scotch-Brite pads, would these be sufficient to get into those small pits? Or would there be something more suited for this?
Also, I am dry sanding, would wet sanding be better?
Thanks!
Thanks!
