TedG
First let me start by say thanks to all the Ford Barners that responded to my questions in the past, I don't think this project would have gotten this far this quickly without their help, the car was delivered to me as a rolling chassis and large pile of body parts in April of 2010.
We finally got some nice weather so we got the Sport Coupe out to try and wrap up a few loose ends, the engine started right up and we quickly got the generator adjusted and were warming it up so we could retorque the head gasket, after running for about 4-5 minutes it started making a horrible screaching sound similar to the noise an alternator makes when charging at a high rate so we quickly shut it off.
Thinking it may be a bearing in the generator I removed the belt and restarted the engine, the noise was still there.
Also thought the throwout bearing may have been the problem so tried working the clutch pedal in and out but that made no change in the noise.
I loosened the lower end of the oil return pipe and oil runs out after the engine is cranked over for a short time so I'm pretty sure there's sufficient oil flow.
Since it does not sound like an internal engine noise and the only other engine related work I did was replacing the distributor shaft & bushings and (becasue the car owner insisted) converted it to electronic ignition, I pulled the distributor, it spins freely by hand with no noise.
If left to sit for 5 mins. or so and then restarting the engine at first there is no noise but after running for a short period the noise returns.
Anyone have any thoughts on what may be causing this?
As always any help would be greatly appreciated.
