Schramm Pneumatic Tractor
MOHOPKINSON
New member
I'm looking at a Schramm pneumatic tractor with a backhoe. The engine has been changed out in the last 20 years, so the numbers of the label on the engine may not help. The replacement engine was used on a stationary pneumatic setup and is of the same make and model as the old engine.
I've tried starting the tractor, but get no spark from the Fairbanks Morse FM style magneto. The distributor and rotor are worn so new parts are in order. I was thinking of sending the magneto to a company to get it looked at and repaired. Any thoughts on who to send it to?
Thank you for any help I can get.
From engine label Model#2COUF Serial#90312-S
Compressor Model#90312-S STU2COUF-1
This area is for questions to the editor about this site not car (tractor) questions. The owners of this site wish to keep the discussion primarily about stock type cars as this is a car not tractor site/forum. Your best bet is to try;
http://www.smokstak.com/
Smokstak would be the perfect fit to your question.
You know I took the time to help you with a suggestion for a better fit to your question. Did you try it? A think you would be nice or even a hey that's just what I need would be great!
I like most of the others that point people to the right place in this section don't get payed and are just trying to be helpful.
