Abchoppers
56 Mercury 312, let me first say I’ve been fighting an issue for about 2 weeks and I think I’m close to solving it, that’s only because of the things I’ve learned from you guys so thank you again.
Car was breaking up, sputtering on acceleration, missing a lot. After doing all the checks I learned here: vacuum a steady 20, compression the same as last time I checked, fuel system is all new, all tune up parts are new including coil. I found that the distributor vacuum advance diaphragm was broke. I replaced it and the issue improved, but not fixed. I finally realized the timing was too advanced after I heard pinging. I’ve never touched the timing before. I’ve retarded the timing and it is very much improved, but still misses on acceleration. The pinging is gone.
I have a Holley 4160 carb that bolts directly to manifold, so I believe I have a 57 manifold, however, I think I still have the dreaded loadomatic distributor. The only vacuum advance that would fit said it was for a 55-56 ford. I also have Petronix electronic ignition. I’ve included pics to help identify.
So is now a good time to upgrade the distributor? If so, will any new 312 y block fit? Any help much appreciated.
