Scat Crank
372dart
Looking to build a motor with this crank. My question, can someone tell me the stock measurement of main and rod caps? So many have been filed down. Gonna be a babbit motor. What is a acceptable cap measurement?:confused:
Well, I am assuming your block/rod is clean and all babbitt removed. Bolt a cap on, sans the shims and mic the bore in 90 degree intervals and compare readings.
FWIW, I have noticed that the Scat cranks, at least the "B" one runs about .001-.0015 larger than a Ford on the mains.
When you have the Babbit done, make sure to take the crank to whoever is doing the job for measurement.
John
