I think I made a mistake when I sealed (DP40) and primed (K36) my car. I used 80 grit sandpaper to shape the filler like most people do. I then applied the sealer and the sanding primer thinking the K36 would "fill" the scratches. Now after 3 or 4 coats of K36, when I use the grease and wax remover, I can see the sandpaper scratches. I think the sandpaper scratches (undoubtedly from the 80 grit) will show if I paint the car with the scratches present. The surfaces seem quite smooth, but you can see the scratches when a glossy liquid like water or grease & wax remover is applied. Next time I will use 150 or 180 to sand out the 80 grit scratches before priming. In the mean time, if I apply a few more coats of K36, should the scratches disappear? Would something like Evercoat FeatherFill high build primer hide the scratches? I don't know if FeatherFill will work OK over K36, as someone told me it shouldn't be used over K36. Any thoughts? This is the first model A I have painted and this is a rookie painting mistake I won't make again. Thanks in advance for any help with this problem.
