Steve Plucker
I have a Harbor F. blast box. What should the air pressure be at the Air Compressor and the regulator before the air gets to the gun?
Thanks.
Pluck
Thanks.
Pluck
A lot has to do with the size and condition of the tip you are using in regards to what size media your are using. Keeping the media clean and having a cyclone or vacuum hooked up along with moisture traps helps. Then also size of tank. We have a 60 gal tank and I run at about 60-70 pounds pressure, tank shut off set at 150. We have a decent compressor running 220, it handles what we do in the shop, but still that tank get depleted quickly a there is a lot of air going thru the tip when in use.
Re the HF box, we have the same one. It is sold under many different names. first thing I would suggest is on the view port, install threaded pop rivet inserts so you can change the plastic glass protector from the outside, then install real lights. You will find in use, the plastic protectors fogs up real fast from media hitting it and is a royal pain to reach inside to hold the nuts for the screws holding the frame on. I hope this year we can install better lighting in ours, I am thinking LED. (along with maybe new tips, ours are plum wore out)
I did the same on my Harbor Freight cabinet. I also caulked all of the joints and seams prior to firing it up for the first time.
