cuzncletus
The installation of the Chassis Engineering suspension under my 39 is going very quickly. The rear is in, next up is the dropped axle and disc brakes. I'm leaning towards a saginaw box but there are a couple of more complications before I decide. First, if the 39 column is used I assume I have to have a u-joint. How is this attached to the steering shaft? If I weld it on, then it becomes impossible to get the shaft out for repair of the steering wheel, correct? The alternative is using a column such as from Ididit. I'm not averse to this as I like the tilt and turn indicators. Can I put my stock 39 wheel back to the Ididit column? How about pan clearance issues?
Thanks for all the knowledgeable input.
