CarlG
What is the best cure for a door (Driver's) that sags enough that it won't latch properly. Lift up on the rear of the door while closing it and it latches good. It is about 3/4" lower on the rear than is the door on the passenger side just judging from the way the belt rail with pinstripe just under the window matches up.
Can the hinge side be shimmed up?
