have a model a crank counterbalanced and sized .030 main and .040 rods can anyone tell me if its o.k. thankyou.
The other question is if the crankshaft is heat treated. On modern cars, cutting too much material starts to expose softer tempered steel/iron, and re-tempering is necessary to longevity - not so much because of heat build-up as much as tensile strength of the journals. Is this an issue applicable to our A's?
