Safe from damage. Modern radiators are designed to hold 15 psi or more; I just wasn't sure if a Model A could do the same.
What's happening is that it is leak free when cold, but after getting up to operating temperature for a while there is some seepage. Im guessing there is a small crack in a solder seam that opens up when hot. I will be preesurizing the radiator only, not the entire cooling system.
