S/W windshield frame disassembly help (160B)
Preacher
does anyone have PICTURES of the windshield frame during restoration? seems that along the way some of my screw holes were filled in. especially focusing on the one on each side at the front top of the frame. It is my understanding all 30-31 closed windshields are the same.
Here's some shots of my 31 coupe frame just before epoxy primer. These holes were trashed and took some welding and leadwork to get things lined up.
I slid a strip of brass into the end before welding the holes.
P.S. I believe the slant is just a bit taller frame with holes in same location.
Excellent, but, what does the single screw thread into? very limited depth. does it thread into the thin corner connector with no nut?
There's a nut @ the backside which tucks under the seal retainer strip.
I have an original in hand.
11/32 wrench size.
8-32 thread.
The screw is only 1/4" long overall ...with a very slight dome to the head.
