S-10 help please
V4F
i have an s-10 conversion in my "A" . it came with the car . the rear end leaks really bad . who can i get info from on changing the seal ? i dont know who made the kit . thank you
Steve, seals have the name of the manufactor stamped on them, and the seal number some where,like C/R, Temkin or who ever made it, if you can get it out and get the number any bearing specilty business can look up the seal, you should shoud have a place near you, i know there is a bearing place in chico, good luck
Steve:
Do you have a vent in the rear end. If the rear end is not vented, pressure will force the grease out the seal when the rear end warms up.
yes it is vented ... thank you !
yes i can pull it & probably find one ez ... was more worried about upsetting the preload ................
You could always do the obvious and ask the local GM dealership. They can tell you where to find the diff. ID info, provide seals, brgs, etc.
yes , open drive shaft conversion . not gm . gm trans but "A" rear end ........
I believe speedway sells the kit to convert banjo to open drive. Something in my memory also wants to say kiwi connection or another australian company. Hope this helps.
Paul in CT
thank you for the info . i think my best bet is to pull the seal ........ thanks all
Steve:
Auto Restorations !-800-955-3139 Makes the kit , You have a sending unit at the rear for yor speedo?
That is the place it came from , no web site he is in Muncie, In 47305
Hope this helps
Skip
Kwik is new Zealin (spelling)they make the quickchange that I have which calls for a vent due to the higher RPM on the rear
