O old31 Well-known member Nov 14, 2024 #3 Not a problem. All he has to do is get on his cell phone and call AAA. Can you imagine trying to explain to someone back in the era what a cell phones is!
marty in Ohio Well-known member Nov 14, 2024 #5 Boy, and you thought you were having a rough day !!! Marty
gdmn852 Well-known member Nov 14, 2024 #6 A Restorer 90 years later, I wonder how the fenders got so bent up ?
Smokedtires Senior Member Nov 14, 2024 #7 How many would attempt that in their A today? Although clearly not a bad choice in cars to try it even today.
Synchro909 Well-known member Nov 14, 2024 #9 I bet the left hand side front door of that car is open. With that much twist in the chassis, there is no way they will close until it is level again. On second thoughts, he probably had to climb over it to get out.
L lrf Senior Member Nov 14, 2024 #10 My guess: He probably once owned a Model T that went on this road many times with no problems.
C CatMan1 Senior Member Nov 15, 2024 #11 It looks like there is someone driving it as the right rear tire appears to be spinning. Maybe? I guess the A's were nearly as flexible as the T's.
katy Well-known member Nov 16, 2024 #13 CatMan1 said: It looks like there is someone driving it as the right rear tire appears to be spinning. Maybe? I guess the A's were nearly as flexible as the T's. Click to expand... One can see what appears to be the top of the drivers hat.
