How much of an issue is it for a small amount of rust to be developing around the point where some of the spokes are welded to the inner hub and also the outer rim of a powder coated 1930-31 original wheel? I believe this might have been caused by a small amount of flexing causing the powder coating to have tiny cracks which allowed moisture to enter and form rust. If this isn't a safety issue I intend to use a Q-tip soaked in Corroseal and dab it onto the rust. This will convert the rust to a stable paintable surface. I will then get a small amount of touch-up paint mixed to match the wheel color (medium cream looks like the closest match according to the Paint & Finish Guide) and using a small artist brush paint just where necessary.
Thanks
Dave
Thanks
Dave
